How to insert Drawing template in DWG format
ismV3CFD
Message 1 of 10
ismV3CFD
Hi
I want to insert my customized drawing template in fusion 360 which is saved in DWG format . Kindly give the suggestion to us as soon as possible.
Thanks & Regards
Divakaran
Replies (9)
Message 2 of 10
BenBisares
Autodesk Support
Autodesk Support
If it's a DWG file containing 2D or 3D data then you can use the steps in this article
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Ben Bisares
Message 3 of 10
ismV3CFD
Hi Ben Bisares
Thanks for your support .
I used the 2D template in AutoCAD  .
I am asking that for drafting purpose  which means I have completed  my  3d modeling in modeling then I switch over to drafting mode that means 2d detailing , after detailing we fix the drawing in template inside that should be we a need help on how to import the AutoCAD template in fusion .
Divakaran
Message 4 of 10
cmiller66
Hi Divakaran,
You can't import an AutoCAD template (.dwt) for use in Fusion drawings.  Fusion has two default drawing templates, ASME and ISO, which control settings like dimension style, sheet size, etc.  You can create a new drawing template in Fusion, but it will be based one one of these two default templates.
If you have a title block (not entire template) created in AutoCAD you can import the DWG, but we limit the DWG you can import to only Fusion-drawings supported entities, no block references, xrefs, etc. Here's some Help info on importing custom title block DWGs: Inserting custom title blocks .
Chris
Message 5 of 10
ismV3CFD
Hi Chris
Thanks for your reply ..
Divakaran
Message 6 of 10
i can not insert my dwg file can some one help me
Message 7 of 10
g-andresen
Xrefs are connections to other files. This can be a document number, for example.
These references must be removed beforehand.
Günther
INFO XREF
Message 8 of 10
then my complete template from inventor are usless 😄
Message 9 of 10
how i can add references to my template in fusion
Message 10 of 10
the next problem is how i can reference the componet /part name
