how to identify thread size on a part ???
ptcjohn
ptcjohn
how do you measure the thread in the attached file.  eg diameter and tpi.
thanks
paul.clauss
Hi @ptcjohn
Thanks for posting! There is not a great way to measure threads in a CAD file in Fusion 360, but the threads in your file can be identified by right-clicking the "Thread3" feature in the browser:
I hope this helps! Please let me know if you have questions.
Paul Clauss
Product Support Specialist
ptcjohn
many thanks.........that will work. its a shame that they dont have properties like in inventor ( in drawing mode they can be dimensioned......)
ptrskiba
Community Visitor
Community Visitor
This is true, but you have to check box "Modeled" to apply thread on the item. Without that option the thread will not be created.
jhackney1972
Even if you do not check "modeled" when you create a thread, it is created in the database of the model.  If you made a 2D drawing and added a thread note to the thread, modeled or not, it would call it out.  Modeled threads are only needed when you need a physical thread for 3D printing or something like that.  They should not be modeled normally due to the high overhead processing required to create them in the model.  The thread is represented by an image if it is not modeled to indicate a thread is present and that all that is needed normally.
John Hackney, Retired
