How to hang an object from a point
danETKQ8
danETKQ8
I have a steel casting that is an odd shape and requires painting. Is there a way to see how a part will hang from a point (simulating a hook) so I can determine if it will hang and how much space it will take up when hanging from the point?
g-andresen
Without seeing the parts it is not possible to give any clues.
Please share the file.
File > Export > Save as f3d locally > Attach to next post
Günther
danETKQ8
Here is the part. I colored a surface red showing where I want to hang the part from.
ercox
Use info function to locate center of gravity.  Draw a construction line from that point to to point you want to hang from then constrain the line vertical.
