How to delete all/any animation
contact
contact
I have a scene that as no animation. It previously had animation but I have removed it all. When I export as .obj file and import into other software I am prompted with importing animation option. There is no animation so it does not seem to matter if I choose yes or no. Regardless, I would like to somehow tell Fusion 360 that there is no animation in the file. If I create a new scene with no animation and export as .obj I an not prompted to import animation in other software. Any help is appreciated.
Phil.E
I'm really confused by your post.
OBJ is a generic file type. Fusion translates your design by stripping out all information other than the body geometry in order to produce an OBJ.
What is the message you see in another software? Can you please post an image of the message you are receiving from other applications?
Does this block you using the OBJ in other applications?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
contact
Its all good now. I was able to solve the issue by recreating the exact same scene from scratch.
