- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Newbie at Fusion 360 -- I've only watched about 40 hours of tutorials. Simple question. I want to define a Sketch point away from the origin (e.g. (25, 50)). I want the position of the Sketch point to be controlled by parameters (e.g lengthXpoint1 = 25, lengthYpoint1 = 50). The only way I can see to do it is by creating an X-axis construction line set to distance lengthXpoint1, and the a vertical construction line from the end of the first one vertically, distance lengthYpoint1.
This seems clumsy and clutters up my canvas. Is there a way to just set the location of a Sketch point using parameters without the intermediary construction lines?
Thanks!
