How to center a rectangle along axis
xilex
xilex
Hi guys, just started learning Fusion 360 this week. I went through a Designing for 3D Printing with Fusion 360 course to get a basic grasp of the software, and am working through a book of CAD exercises to learn. On the below image, I am trying to center the rectangle outlined in blue so that it is centered along the orange line and the long horizontal line. What is the best way to accomplish this?
My solution was to create midpoints along each side of the rectangle. Then I used coincident constraint for the midpoint of the rectangle and the axis. An alternative solution I thought of would have been to calculate exact dimensions and use that to constrain it, but I think this is not best way. Was the first solution the ideal? Thank you.
davebYYPCU
Sooo many ways, do what suits you, no right or wrong some are better....
Sketch point on the intersection of the two datum lines involved,
Centre point rectangle should snap to that point.
Might help...
g-andresen
here are two ways.
günther
MoshiurRashid
Almost same process like previous screencast but a little bit different in constrains.
https://knowledge.autodesk.com/community/screencast/ce442f1e-7e95-4c97-b9da-e223c3c2ec18
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
xilex
Thanks, that is way more straight forward 😁
