How to arrange components making sure it is horizontal to the stock.
- Mute
- Permalink
- Report
I am designing fins, basically a foil, sometimes both curved sides sometimes one flat side, they also have a base set at different angles depending on which model im using. I need to arrange in the manufacture panel so that the foil is horizontal and within the stock. At the moment i have been arranging and it is giving me some problems.
1. When i try to arrange into a sketch or onto a plane, the just over lay each other and dont stay separated.
2. They are not using the correct face as orientation to bottom of the stock.
Here is one fin as close to how id like it to arrange into a stock.
I select these objects
I select the sketch, as you can see they overlap, and they are along the edge of the sketch.
And as you can see it has flipped one and used the wrong flat face as the reference to the x axis plane
Surely there is some way to fix this?
