how to 3d print a model modelled in SURFACE mode
I have modelled a Arm shield as a Prop and I want to 3d Print it, But it is in Surface mode, I tried to thicken it but it doesn't work. What should I do to give it mass? And 3D print it?
Thanks!
MoshiurRashid
Hi @Anonymous
Thanks for posting. The model has some attempt of blending surfaces. And those are not done well. So, it can't use thicken command. Because thicken makes an offset of the surface and make it closed solid afterwards. I could fix the issue but you are using Fusion 360 in non parametric mode. So, I cant edit the operations.
So, for quick fix, I created a hollow solid by using lofted cut. It is not in perfect state, but you can 3d print it anyway.
Also, There is a closed solid version in the attachment. Check if you are looking for which one.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Thank You so much! You are a saviour 🙂
Can you pls explain how you converted it into a solid body?
Many kind thanks! 🙂
g-andresen
Register „Surface“ > „Thicken“. Use „Stitch“ before if you have several faces.
günther
MoshiurRashid
@Anonymous
I patched the open areas then used stitched all the surface to make solid.
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
