How do you scale a spline?
jrspam29
jrspam29
Community Visitor
Community Visitor
How do you scale a fit-spline with curvature and preserve the shape?
Every 3D program I've ever used from Maya, to Autodesk, to Softimage, and even Blender can scale a spline without distorting the shape. Even 2D programs like Illustrator and Photoshop will scale a spline no problem.
In fusion when I scale a fit spline in a sketch, it can't preserve the curvature.
it "puckers" at every control point.
is there a solution for this? Or can we convince the programmers that this is crazy considering every other graphics program can scale a spline properly?
Radwan-Almsora
The distortion happens because Fusion’s Fit Point Splines consist of points and static tangency handles. While the points scale, the handles do not. To scale without the "puckered" distortion, you can use a Control Point Spline, project the spline as a silhouette, or perform the scaling outside the sketch environment.
To resolve your issue, you can enter here.
How to scale a sketch in Autodesk Fusion
Radwan-Almsora
don't forget to click the Accept Solution button and leave a < like !
andrew2085
I would call this a bug. The problem isn't that scale isn't scaling the handles, it's that it IS scaling the handles that have been edited, when it should not. You can check this by creating a sketch and drawing a spline, editing one of the handles, copying it, then scaling the copy. The Copy does not have the same shape as the original spline because it scaled the handle you edited. If you make the first spline fixed and put a driven dimension on the length of the edited handle, and put a driving dimension on the corresponding handle on the copy, the shape will change to the same as the original. It seems like this was just a mistake that was made in the implementation of the scale tool. I can't really think of a reason why you would want an edited handle to scale along with the spline.
Edit: I was wrong, the handles do need to be scaled by the same amount. The issue is that when you edit certain handles then scale, it does scale the handles that you edited, but its doing something else to the rest of the handles. They are not scaled by the same amount, but they are also not left the same.
Edit: I think what's happening is that Fusion is only scaling the spline data (fit points and edited handles), and then handing that to the spline solver to be re-solved from scratch instead of handing it over a known solution (scaled fit points, edited handles, implicit handles, and maybe control points) for it to start from. So I'm not so sure if its a bug or just a limitation of the spline solver, but it is a solvable problem.
