How do you position an imported component using parametric modeling?
I am designing a router table that has casters, which I have imported from McMaster Carr.  I am using the parametric modeling table because I am still tweaking the dimensions prior to assembly.  However, if I change a parameter, the position of the casters does not update with the rest of the model.  For example, if I add 2 inches to the length of the leg, I want the caster to drop 2 inches.  I have tried using a rigid joint to join the caster and leg, but that didn't work.  Is there a way to fix an imported component relative to another component so that when the dimensions change, the postion of the improted component update properly?
Thanks for your help
jhackney1972
There should be no issue with your design.  You want to make sure your have the correct component grounded so everything can update correctly.  Take a look at my Screencast where I have a simple assembly with a McMaster-Carr swivel caster in the end of the leg.  I have a length parameter on the leg component.  If you need additional help, give the forum a link to your assembly so we can take a look at your actual design.
John Hackney, Retired
Thank you for the quick reply.  I had not grounded any components, but unfortunately this didn't seem to solve my problem.  I tried grounding the bottom frame, then tried the top.  Each different time I made rigid joints between each part from the grounded part to the caster (e.g Top -->Leg-->Bottom Frame--Caster).  Every way I tried it, the casters stayed still while the rest of the table changed size.  The components are nested together.  I also tried joining individual instances of a caster, pulling the casters out of the nested component.  I'm sure its something simple I'm missing.  Thanks again.
Here is a link to my project: https://a360.co/2VJgIYG
jhackney1972
What I found was that one of the legs was lacking the parameter that governed its length.  Also the Rigid joint between the casters and the frame not to a member that was changing position.  I removed all these joints and replaced one.  I am not sure it the location is exactly correct but I just wanted to prove a point.  Your ground component is just fine, the table top.  I have attached my modification assembly with a different name to this post so you will not confuse it with yours.  I only did one caster as I am not the designer and I want you to place them as you desire.  Just select a joint origin point that changes with the table height.  The one caster I changed updates with the table height.  Why did you create a sub-assembly with just the casters, nothing wrong with it but...
So I got it to work but I'm not sure what went wrong.  How I fixed it was deleting the casters, re-importing them one at a time, then creating the joint, and it worked as it should. The only difference in process I can remember is the way I copied the casters.  The first time, I inserted one, then mirrored it twice to get 4 copies.  The second time, I inserted 4 individual instances of the casters.  I'm guessing the mirroring was the problem.
Either way, your advice led me down the right path.  Thank you again.
I nested the components so I can easily hide them with one click while tinkering with the other parts.
jhackney1972
Next time, group your components in a Selection Set instead of a sub-assembly.  You can show, hide or isolate selection sets very easy.  Please mark your forum post as "solved" if you have your answer.  This is a good habit to get into when a forum question is finished.  It helps others find your solution and it removes it from searches.
