第 1 条消息(共 7 条)
不适用
04-28-2020
01:53 PM
I am designing a router table that has casters, which I have imported from McMaster Carr. I am using the parametric modeling table because I am still tweaking the dimensions prior to assembly. However, if I change a parameter, the position of the casters does not update with the rest of the model. For example, if I add 2 inches to the length of the leg, I want the caster to drop 2 inches. I have tried using a rigid joint to join the caster and leg, but that didn't work. Is there a way to fix an imported component relative to another component so that when the dimensions change, the postion of the improted component update properly?
Thanks for your help
已解决! 转到解答。
