How do you get additional document settings?
kriscjhunt
Observer Observer
kriscjhunt
Observer
Observer
The only document setting I have is Units. Where are all the other settings, like Line Widths?
-KyleWilliams-
Hey @kriscjhunt
For the design workspace there won't be anything for changing line widths. There are some other settings in the properties area by clicking on your user image in the top right. You can also change some viewport properties in the bottom of the work area.
If you're thinking the drawings workspace for 2D you will see settings like line widths under the document settings dropdown.
Hope that helps.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
g-andresen
In the design workspace, sketches are used to create 3D components.
Line widths do not play a role here.
Views are then derived from this 3D model in drawing mode, e.g. for production.
There are numerous options for designing lines in these views.
günther
connie_lab1
Community Visitor
Community Visitor
Hi, So no additional document settings for text carving?
g-andresen
The engraving is done in manufacture mode.
To do this, select the “Engrave” processing and the font as an object as well as a milling cutter (V-bit).
The cutter removes the inside of the letters, whereby the cutting depth is (automatically) controlled depending on the line spacing.
I.e. the greater the distance, the greater the milling depth
Günther
