How do you create a new tool library in the cloud
tjtalma
tjtalma
Just as the title says how do you create a new tool library in the cloud?
I have one library for flat end mills. I do not recall how I added it. I would like to keep all my tools in the cloud because I access fusion from my office PC and shop PC.
What I am doing:
Select CAM
Click on tool Library
Right click on Cloud, select "New tool Library"
New entry appears under cloud. I type name "Threading Tools" press enter
New entry name changes to "New Library", library is empty
I right click on "New Library", no option to rename.
I add new threading tool to "New Library"
I click OK
Click on 2d threading under cam menu
Click on select tool
"New library" is gone, as well as new threading tool
I open Library and "New Library" is gone.
Try adding again.
Same as above, as soon as I click "OK" tool window closes, next time I open "New Library" is gone
I would like to be able to add Library's as I will have lots of tools and would like to keep them organized. And don't want to re-enter the tool each time I need to use it.
What am I doing wrong?
masa.minohara
Hi @tjtalma,
Thank you for posting in the forum! I believe you are doing everything correctly but seeing a known issue with CAM tool library (CAM-10670) and the development team is working on this right now.
Does a new library stay in the cloud if you don't change its name when creating? (Keep the name as it is, for example, New Library 1 ) If this does not work as a workaround, you may be experiencing something difference. Would you be able to record a screencast of the behavior so I could take a closer look?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
tjtalma
If I leave the name new library without changing the library stays.
masa.minohara
Hi @tjtalma,
Thank you for the update! In that case, I believe you are seeing the known issue, and we are planning to release a fix within this month.
Again, I apologize for the inconvenience.
Masanobu Minohara
