How do I create a solid from this sketch?
damian.ravend
damian.ravend
Hi I have an assignment and I need to find the center of mass for this shape, but I cant manage to convert this sketch into a solid and I'm quite new so I don't no much, I've tried lofting, patching surfaces, and stitching but it never works.Screenshot 2022-02-12 202541.png
hamid.sh.
Except for the body of the airplane your sketch doesn't constitute a volume, so how do you expect to have a center of mass for the whole model? If sketches of wings and tail were making a volume I would suggest to Patch every profile and then Boundary Fill. Then you would have a solid model of the whole airplane which Inspect >  Center of Mass could be used. Not that one cannot turn this sketch to a solid body, but assumptions are needed to be made about wings and tail. For example Patch, then Thicken (but what thickness?), or Loft wing's tip to the main body, etc.
Hamid
damian.ravend
Hi I've ended up using loft and thicken. That works too though, thanks for the response 😀
