How could i extrude this?
swerecon
swerecon
I scaled down a component for a project and it worked well. But i need to make parts a bit thicker but cant use the push/pull command becouse of some fillet/scamfer made original. Added the file for you to look at. Is it possible for example to make the large sides 1,5 mm thick instead of as now 0,3 mm?
jhackney1972
I have created an external body with a thickness of 1.2 mm to the outside of your model.  If you would like, you can use the Combine command to Join it to the main body to make a total thickness of 1.5 mm but I will leave that up to you.  Model is attached.
Next time you share a model please attach a "native" Fusion model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
swerecon
Thanks for helping. Iám not sure it will solve my problems. I have some more parts and iám not sure this will be the way. Isn´t there a way to get rid of scamfer/fillets like in Oneshape?
I will upload in another format next time, didnt know it was better.
TrippyLighting
It is only better if it has a timeline that shows how the part was designed to begin with. A timeline makes it a lot easier to resolve problems!
