How can I replicate this square dome shape?
adammarkwalker
adammarkwalker
Im trying to recreate the item below as a learning project and im trying to make the dome shape that is the top of the dalek...
Ive tried using a fillet tool but it doesnt quite do the same and I dont like the way it looks
jhackney1972
You can use a Sweep with your desired shape.  To select all sides of the square for you path, be sure to hold the Ctrl (Command) key down while selecting the edges.  Model attached for you to play with.
John Hackney, Retired
TrippyLighting
Do you have larger images and views from a different perspective?
