Hot key/shortcut master list
Why don't we get an option do change/assign shortcuts from preferences like in older versions?
I find it very limiting to need to find them in the menu and then assign the short cut.
For example I want to use middle mouse button to pan and then shift+p to move the camera but can't find a way to change this.
sanjana.shankar.goli
Autodesk Support
Autodesk Support
Hi @Anonymous ,
To modify your mouse controls easily, you may use the quick setup dialog from the help menu (question mark icon) on the top right corner in Fusion 360.
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
From that menu I can pick pre made setting (like solid works style) but still don't see how to make my own (ie. set orbit to middle mouse button and pan to "shift + P")
Autodesk Support
Autodesk Support
With the Solidworks style, the Orbit works with the middle mouse button. To assign shift+p to pan you may create an API or use existing ones from the Fusion App Store. Check out the AnyShortcut App .
Sanjana Goli
Thank you so much! 😄
A combination of your tips worked!
I set quick setup and navigation view to solid works and used the shortcut plugin to reassign pan.
