Horizontally dimensioning between circles
grramire
grramire
For some reason I can only dimension the distance between the first circle to the second at the weird angle in the picture. I would like to dimension it this way:
Please help
HughesTooling
After the dimension's created you can't change from aligned to vertical so you'll need to delete and add again. Normally you can move the mouse to change from aligned the horizontal\vertical but if you can't get this to work you can right click while the dimension's active and specify the type you want.
Mark
Mark Hughes
Owner, Hughes Tooling
TheCADWhisperer
Is your Origin in a logical position making use of obvious symmetry?
g-andresen
this is how it works
günther
grramire
Yes I have just attached it
TheCADWhisperer
Are you horizontal lines constrained Horizontal?
Are your arcs Tangent?
Are you attempting to follow a Tutorial or other instructions (I have seen this design posted here in the past)?
Is everything on the same sketch plane (a 2D sketch rather than a 3D sketch)?
What happens if you select the 3 circles, Right Mouse Button and select Move to Sketch Plane?
