Hole tool dialog bug
LiveLover
LiveLover
Hello!
Hole tool dialog bug: see screencast.
Please create it if not already.
g-andresen
The marking problem occurs irregularly with different menus.
Maybe @jeff_strater  can say something about this?
günther
Rushikesh.kadam
@LiveLover Thank you for reporting the issue. I see that the OK button is disabled and the thread depth field is highlighted red even with a valid value.
Created a ticket to fix it.
Appreciate your effort for reporting it.
If my reply was helpful, please click the "Accept as Solution" or the “Like” button. This helps others to find the answer more quickly!
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
g-andresen
Hallo,
here is another example from the "Edit Pattern" menu.
günther
günther
LiveLover
Cool! @Rushikesh.kadam  Thank you!
