History bar not showing
andrew.todd1
andrew.todd1
See screenshot. logged on this eveing and unable to load anything ive been working on.
when I click the bar on the left it dissapears..
Help!
julia.paganucci
Autodesk Support
Autodesk Support
Hi @andrew.todd1 ,
Thanks for posting! Can you please try restarting Fusion 360 ? Can you also post your graphics diagnostics information (click on the question mark in the upper right corner, click support and diagnostics, click graphics diagnostics).
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
andrew.todd1
Hi Julia
I have restarted Fusion many times.
See graphics diagnostics attached.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @andrew.todd1 ,
Thank you for the screenshot. Can you please check the box in that window that says "limit effects to optimize performance"?
Can you also click on your name in the upper right hand corner and go to preferences. Change the graphics driver to DirectX9.
Since this is new behavior for you, it also may be beneficial to perform an automatic clean uninstall and reinstall
Julia Paganucci
andrew.todd1
Hi Julia
Thanks again for the help.
A fresh install sorted the problem 🙂
Andrew
