- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm running Fusion 360 on an i5 Surface Pro 4 with a 2736 x 1824 display running Windows 10, and I'm struggling to get it to utilize the high resolution screen. By default, Fusion will load in a reduced resolution mode (presumably 50% resolution)...
I've tried overriding the high DPI behaviour in the shortcut properties, choosing 'Application' gives me full resolution but small icons and other interface problems...
The 'System' override option is the same result as default, and 'System (Enhanced)' is the same as default but the actual rendered bit of the screen is scaled down to about 50% of the screen. I've also tried running with windows scaling set to 100% (default is 200%), but that just results in tiny everything.
I've seen various screenshots that show Fusion running in high DPI mode correctly (high res icons etc.), does anyone know how to make it work correctly?
Also, if anyone is running a high DPI screen could they post a screenshot to confirm it's possible?
