Hiding sketch with V key no longer functions
subversivespeed
Message 1 of 9
subversivespeed
click on sketch element, hit V, nothing happens.
It used to hide sketch. It seems it is broken. Not a HUGE deal but as with many things, when something is wrong with a low level function it usually means more gremlins are around the corner. LOL
Replies (8)
Message 2 of 9
jeff_strater
it seems to work for me.  Can you capture this behavior in a video/screencast?
Jeff Strater
Engineering Director
Message 3 of 9
subversivespeed
No..
You are just being a wiseguy right?!? 😂
The elements of a good software is that you ALMOST NEVER EVER HAVE TO USE THE TREE cuz.. only monkeys play in trees.. . 🤣 But it looks like this software occasionally tries to go back to the "Shock the Monkey" days..Actually I think autocad 12 even had this ability.. 🤔
used to be able to double CLICK on a sketch element  and then it would select the entire related sketch elements, then hit V to hide/unhide..
but.. what I noticed is if you click on a CLOSED sketch element it works, if you click on an isolated sketch element, it doesn't work.
I am NOT trying to get carpal tunnel or win a mouse mileage contest..
FIX IT AND QUIT PLAYING AROUND ALREADY!!!! 😘
Message 4 of 9
subversivespeed
Ill put up a vid later but im not trying to do tech support stuff when I got bossman down my back. 😯
Message 5 of 9
jeff_strater
I feel fairly certain that no behavior has changed in this area in a very long time.  The "v" hotkey only works on an entire sketch selection.  Double clicking on a sketch line/curve selects a chain of sketch curves, it does not select the entire sketch, and I'm pretty certain never has.  And, I'm also pretty certain that "v" has never acted on a chain of sketch curves.
I understand that you dislike the way it works, and that is a valid criticism, but I don't believe (I can always be proven wrong, of course) that the behavior has changed.
Jeff Strater
Message 6 of 9
subversivespeed
. So for every other type of element, double clicking selects the entire tree elementl IE clicking on a face of a 3d object selects the face.. Double clicking on the same face selects the entire 3d object, and then allows one to use V hide/show on the entire category.
So.. Sketch has a different behavior.. It works IF the sketch objects are linked and can produce a valid extrusion AND you double click in the CENTER of the sketch .. but.. If I click on a single sketch line, it will usually simply hide that SINGLE TREE ELEMENT.. Which is a bit odd.
If I double click on the single sketch line, it SHOULD select ALL items within that category and allow me to V hide/show the entire tree element if we are to be consistent in the UI operation.
See it in the video here:
Message 7 of 9
subversivespeed
Also when I try to insert a screencast it says "invalid HTML was removed".
SO yeah...
Message 8 of 9
subversivespeed
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/4ad96e2f-b1e4-4abf-b207-4ad090622c6d" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 9 of 9
subversivespeed
