Hide/show model in manufacturing doesn't work anymore. Subject to crash F360.
to3dornottobe
Message 1 of 11
to3dornottobe
Easy to reproduce;
Create a model, go to manufacturing workspace add a setup, create an opp.
hide, and try to show the model again. Impossible.
Had F360 crash a few times due to this
Had this situation 2 times in the passed couple of days with linked models (vice and vacuum table) and it's easy to reproduce.
Workaround is to go to design, select isolate and go back to manufacturing again.
https://autode.sk/2YB1HsD
Replies (10)
Message 2 of 11
HughesTooling
If you click the radio button at the other end it should enable the visibility. Think the problem is because this is the top level component. Personally I never create anything at the top level, only sub components so never run into this before. Probably should work better than this though, think it might have something to do with manufacturing models as you could have several copies.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 11
HughesTooling
This is what I mean, you select the models you want active with the radio button and the others are made invisible. Probably something that needs finishing after adding the manufacturing models option.
Mark
Mark Hughes
Message 4 of 11
to3dornottobe
yada
Message 5 of 11
to3dornottobe
I agree on sub-model structure when it uses more than 1 body. It simple works better then, fully agreed.
Let me refine the subject to 'unable to hide/show top level component' Still, it manages to crash Fusion and i'm working this way for years for simple single body objects. (i don't feel the need for adding a component for simple single body designs) The issue floats to the surface after the latest? update.
Message 6 of 11
HughesTooling
@seth.madore  Is this problem known?
@to3dornottobe  Does it still crash if you use the radio button to change visibility?
Mark
Mark Hughes
Message 7 of 11
seth.madore
Yes, these are tracked as: CAM-27099 and CAM-27220
Seth Madore
Message 8 of 11
to3dornottobe
It's more random and less controllable when using the radio button. It worked ar first, but after 2 times or so it was acting very strange. Had to click another that was already checked, and that lit up the unchecked one too.
So it's a known problem?
Message 9 of 11
seth.madore
@to3dornottobe yes, known issue
-EDIT-
It should get fixed in the next Hotfix that rolls out.
Seth Madore
Message 10 of 11
seth.madore
Actually, the HotFix just rolled out! Restart, engage the update, restart when it's down downloading
Seth Madore
Message 11 of 11
to3dornottobe
Yihaa! tested, works like a charm!  Another thing that was bugging me is gone too. The right click after loading a template with 12 opps was slow. this is gone too. It took some time before you could right-click an opp to select contours and boundaries and such, but this works fast again too.
