Help with Simple Chamfer
toobdude
toobdude
[Post title edited by CGBenner 9/10/24]
Hi Guys,
I am working on Designing this Custom Shift Handle and I cannot figure out why Fusion will not let me Chamfer either side (need both to be about .25" Corner).  I know you pros def have the best/simplest solution, so please let me know what you think.  Appreciate the help ahead of time.
Thanks!  -Ian
davebYYPCU
Curve Comb like this?  Obvious!
Way too many spline points.  Imported sketch?
No free lunches in Fusion.  Redraw it with lines and arcs.
Might help....
toobdude
Expert in the room!  Well I tried to trace an imported canvas using splines and clearly failed.  I know how to 3D print more than design, so I'll try again from scratch.  Sorry for the waste of time b/c clearly I have some spaghetti chart action going on 😕
davebYYPCU
Trace the canvass by adding
all (any) straight lines first including (to be filleted corners).  Then depending on the actual shape, add tangent arcs to the ends of the straight lines.(line click hold drag release)
add more tangent arcs / splines as required to finish the shape.
When all connections are tangent joined, the chamfer, fillet and Sweep commands will be happy.
Trace of your sketch sharp corners will be replaced by model fillets after the extrude etc.  (Two splines with 5 points total.)
Gets you here no drama
Might help….
CGBenner
@toobdude Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
toobdude
Appreciate the Awesome help my friends!!  I re-did my model using those aforementioned best practices, and then was able to come up with the perfect design for my offroad grab handle.  Thanks again for the detailed instructions, -Ian
