- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been working with Fusion 360 for a couple weeks now. Watching a lot of videos and reading the forums. I have seem some posts similar to this one, but the solutions there don't seem to be working for me.
I am trying to use Chamfer to round the edge between to perpendicular surfaces. It was successful where the surfaces were longer and smother. However, when the design has more sharper corners and/or curves I get an error "The fillet/chamfer could not be created at the requested size. This might be occurring at the ends of the selected edges."
In the attached picture you can see the line that seems to be giving me issues. There another attached picture with some of the areas working. And a third picture of another drawing that worked fine (but had longer straighter lines).
Basically, I am trying to have a gradual slope up from the base to the side all the way around the object. The slope needs to be the same all the way around the object and I would like the entire base to be covered by it. If there is a better way to accomplish this, I am open to it.
Thanks.
