Help Request: Vague Error on DXF Export
lothian_mcadam
lothian_mcadam
"X There was an unexpected problem with exporting the flat pattern as a DXF file."
I get this error msg each time I attempt to export a DXF.
The design is attached. What have I missed?
jhackney1972
I do not know the cause of the error in the DXF Export from the model, as of yet, but the 1:1 DXF output, created from the Drawing Environment is attached.
John Hackney, Retired
jhackney1972
Again, I do not know why, as of yet, but if you remove the check marks to include Visible Geometry from the DXF output from the model, it succeeds.  This DXF is attached.
Edit:  It would seem the culprit is the Mirror at the end of the timeline.  Remove it and all works, in the model, as it should.
