Inserted Canvas is no longer visible
2davidcampbell
Message 1 of 24
2davidcampbell
I am very new to Fusion 360 and am having trouble with an inserted canvas.  I was able to insert and calibrate the canvas and begin sketching.  The image is a jpeg of a home floor plan. However, after saving my latest version the canvas field now shows up gray but the image is not visible.  Did I accidentally turn something off? Any suggestions would be helpful.
Thank you,
Replies (23)
Message 2 of 24
jhackney1972
Attach your model file and let the forum users take a look, attach the JPEG as well.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 3 of 24
2davidcampbell
I have attached the file.
Thank you
Message 4 of 24
jhackney1972
You did not attach the image file that you created the canvas from, please do that also.
Message 5 of 24
2davidcampbell
Here is the canvas file.
Message 6 of 24
jhackney1972
Once I had the JPEG, a simple refresh fixed the issue.  Did you do the same or attempt to?  When this happens again, be sure you Edit the Canvas and reselect the image file, most of the time it will update.  There is a possibility that you may have also move the JPEG from the original folder that you attached the canvas from.  Model is attached.
Message 7 of 24
2davidcampbell
No I didn't. Not sure what you mean by refreshing the JPEG
Message 8 of 24
jhackney1972
Basically re-assigning the JPEG to the canvas which makes sure Fusion 360 is looking at the right image file in the right folder.
Message 9 of 24
2davidcampbell
Thank you John, I appreciate your help.
Message 10 of 24
bernie_rihn
how is this still a bug? just happened.
Message 11 of 24
bernie_rihn
aaaaand i can't actually "refresh" it because it loses all my positioning and scaling. *blows brains out*
how do people use this?
Message 12 of 24
jechristJE5J2
This same thing has just happened to me (2 May 2025).  "The image" outline is still there, calibrated, moved and aligned (appearance-wise) but the actual image is not showing.  If I refresh in the way shown in this thread (thanks for the video), the image reappears but it is not calibrated and aligned.  Now that I am done with the model, I wanted to compare one last time to the model.  This is a real drag that the image is not showing.
P.S.  This has nothing to do with the "timeline" of the canvas since it was added well before any of the modeling occurred and has not been moved in the timeline.  Any thoughts?
Message 13 of 24
TheCADWhisperer
@jechristJE5J2
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Message 14 of 24
jechristJE5J2
I have two canvases in this .f3d file that are both from .jpg files (all
files are included in this email). They have both "disappeared". The
image/canvas I care most about is the one labeled Spirit100_canopySide.jpg.
It is the one in the XY plane or showing in the "Front" view. Any
suggestions are appreciated. As a side, I also can't seem to get the two
"bubble" half to "combined". One is a mirror of the other. I'm not super
concerned about that other than slightly interested in why they won't
combined. I can't say I am a Fusion 360 expert... 😉
Thanks for help in advance,
Jeff Christensen
Message 15 of 24
TheCADWhisperer
Hmmm, that is interesting.
I replied earlier today and my post is gone?
Pinging @CGBenner
@jechristJE5J2
Cannot use email replies - must reply by the web forum
Message 16 of 24
jechristJE5J2
I look forward to any feedback you can provide.
Message 17 of 24
TheCADWhisperer
@jechristJE5J2 wrote:
 (all files are included in this email).
@jechristJE5J2
I'll try one more time.
You cannot attach files by email reply.
You must use the web-based forum.
Message 18 of 24
jechristJE5J2
Here is an abridged version of the email I sent with the files attached to the "web forum" reply.
I have two canvases in this .f3d file that are both from .jpg files.  They have both “disappeared”.  The image/canvas I care most about is the one labeled Spirit100_canopySide.jpg.  It is the one in the XY plane or showing in the “Front” view.  Any suggestions are appreciated.  As a side, I also can’t seem to get the two “bubble” half to “combined”.  One is a mirror of the other.  I’m not super concerned about that other than slightly interested in why they won’t combined.
Message 19 of 24
jechristJE5J2
So I provided all of the files you requested via this forum and I am still waiting for a response.
Message 20 of 24
thetomerpeer
Community Visitor
Community Visitor
This just happened to me as well. In my case, I accidentally moved the image file, which made it disappear, but it wouldn't reappear after returning the image back to the original directory. As others already said, re-loading the same image loses the calibration, so that solution won't work at the moment.
Is there a good way to resolve this issue?
Also, why isn't the image data being saved into the project file to prevent this kind of silly problems?
