Help on the new update
mouayad.al123
Message 1 of 13
mouayad.al123
Hello may I get the older version of fusion 360 because the latest version really bothers me
Replies (12)
Message 2 of 13
RajkumarIlanchelian
@mouayad.al123 Can you please expand on what is not working for you in the latest update?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 13
mouayad.al123
The 10 document limit is really annoying me and it did not exist in the last version and that is why I want to downgrade to the older version
Message 4 of 13
RajkumarIlanchelian
@mouayad.al123 The 10 document limit was introduced in the latest update. It was communicated that this was coming a few months back.
Are there issues using workflow to activate documents etc?
Autodesk Fusion
Join Fusion Insider
Message 5 of 13
mouayad.al123
What do you mean?
Message 6 of 13
RajkumarIlanchelian
@mouayad.al123  Basically is it not working as we mentioned it would.
Autodesk Fusion
Join Fusion Insider
Message 7 of 13
mouayad.al123
It is working but it is annoying me so I want to downgradede
Message 8 of 13
RajkumarIlanchelian
@mouayad.al123 Fusion does not have the option to downgrade.
Autodesk Fusion
Join Fusion Insider
Message 9 of 13
mouayad.al123
I want the file for the old version
Message 10 of 13
RajkumarIlanchelian
@mouayad.al123 You can access the old versions you saved in your data panel under the design and versions. All your saved versions are shown to you. You can promote an older version to be the tip version etc.
Autodesk Fusion
Join Fusion Insider
Message 11 of 13
mouayad.al123
Where is that I can't find it
Message 12 of 13
RajkumarIlanchelian
here is an image for n example:
1. Go to data panel
2. Go to the design you want
3. Expand the version and it will list all your saved versions
Autodesk Fusion
Join Fusion Insider
Message 13 of 13
mouayad.al123
That is not what I meant but thanks
