Help needed making a circular pattern of a emboss face
javiguajardolever
javiguajardolever
I cant seem to be able to make a cicular pattern for a lamp shade. I keep getting the same mistake Error: R-Pattern1
Compute Failed. I've posted the file
jhackney1972
Please clarify what you are trying to pattern as it seems that the pattern of the Embossing is succeeding.
John Hackney, Retired
g-andresen
I think the problem is with the number of pattern 1. If you enter an even number (e.g. 12) there, you can also generate the second pattern with 6 instances.
günther
javiguajardolever
I tried with a even number and I get the same compute failure
javiguajardolever
Yes, I didn´t have issue with the embossing. I can´t make a pattern (circular or rectangular) without getting a failure
jeff_strater
I see the same as @jhackney1972 - this pattern of emboss computes correctly in the design you shared:
Can you share more info about what fails?
Jeff Strater
Engineering Director
g-andresen
have a look at screencast and file
(view in My Videos)
günther
