Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Help!Fusion 360 modeling area freezes after few minutes inactivity.
nennu32
Message 1 of 16
nennu32
I have a issue - My graphics area(where my model is displayed) will freeze after a few minutes inactivity . Cant move, edit, zoom. All menus and submenus working fine. I even can save my model. I cant open any other models and start new one if this freeze has happend. Only restarting fusion helps. I`ve tryed to log out and in, run fusion as administrator, all drivers are up to date and even reinstalled Fusion 360.
Replies (15)
Message 2 of 16
Phil.E
Are you using more than  one monitor?
Can you please get log files the next time this happens? Restart Fusion, go to Help > Support and Diagnostics > Diagnostic Log Files to use the command that gathers logs.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 16
tja_first
I am experiencing something very similar. The trigger for the problem seems to be the screen saver - in my case I'm using BOINC Manager to run background computations while I'm not using the computer. Whenever I return to the desktop and Fusion 360 from the screen saver:
A. Any loaded models have disappeared from the display window, as has the view cube.
B. Opening a new tab or loading another model results in the same empty display.
C. Disabling then enabling the view cube does not restore its visibility.
D. File save and other menu items seem to work.
I'm attaching the diagnostics log.
Tom
Message 4 of 16
Phil.E
What you are describing sounds completely different. The OP does not mention the computer going to sleep, or the effects you describe, which sound like graphics have failed.
Could you check your graphics diagnostic for me? It's on the help menu, support and diagnostics sub menu. The dialog has a way to copy it all to clipboard so you can post here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 16
tja_first
[GPU Information]
GPU Device: Intel(R) HD Graphics 4600
GPU RAM: 112 MB (Integrated card)
GPU Driver API: DirectX 9.0
GPU Driver Version: 20.19.15.4531
GPU Driver Date: 03/14/2017
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Message 6 of 16
Phil.E
You could try updating your drivers. Those are 3 (nearly 4) years old. The latest are from a couple months ago.
https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600
Another thing you could try is limiting the graphics effects. In that same dialog that gave you the diagnostic data, there's a check box that can disable all graphics effects. You want that "on", currently it's "off".
(this should be On rather than Off)
Keep in mind that your graphics card is an integrated kind, with very little memory. If you are using two monitors this will strain it even more. So turning off effects is a good way to reduce the strain.
Good luck, and please let me know how it goes.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 16
nennu32
Im using a laptop and second monitor- added diagnostic files. Collected after it happened again.
[GPU Information]
GPU Device: Intel(R) HD Graphics Family
GPU Driver Version: 20.19.15.5126
GPU Driver Date: 06/16/2020
Anti Aliasing: On
Object Shadow: Off
Ground Shadow: On
Off
Message 8 of 16
nennu32
 Clip to sitution https://youtu.be/_otjdDn_NWI
Message 9 of 16
davideemilio.marazza
i have the same problem (opened a post as well).
It become like that with the latest Fusion 360 update some days ago. It was working just fine before that...
Message 10 of 16
tja_first
Intel® Driver & Support Assistant reports:
"A customized computer manufacturer driver is installed on your computer. The Intel Driver & Support Assistant is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact Dell for the latest driver for your computer."
The most recent driver version from Dell is the one I've got.
I enabled [Limit effects to optimize performance], but the problem remains.
BTW, I just performed the Fusion 360 version update. No problems before that.
Also, I'm using one monitor.
Message 11 of 16
Phil.E
We've discovered a reason for this unfortunate bug. It affects certain video cards. We're working on a fix at this time, but since we can't promise when it can be released it would be best to try the workaround in this article.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Mod...
Please let me know if that helps.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 12 of 16
nennu32
For me the cause of it seems to be windows screen saver. If I disabled it I could work without any problems all the 10hrs shift. In the morning when I get back to work it was still working. Now I did a little test- I only previewed windows screen saver and simutaniously Fusion got freezed.  Ill try this link also what you posted Phil.L
Message 13 of 16
tja_first
That seems to work. The display remained in its normal state through several screen saver cycles. I also re-enabled the effects setting and that worked as well. Looks like that should keep me going for now. Thanks!
Message 14 of 16
nennu32
It seems so this is a solution.  Test it with screen saver and no problems anymore. Thanks!
Message 15 of 16
erwin
Hi Phil, unfortunately, this did not help with the issue for me. I am also using an integrated Intel HD graphics 3000 card.....
Message 16 of 16
phil_eichmiller
Did you try disabling screensaver?
