Hello! It is posible to make in fusion 360, aksial following and rotating move of road in same time
FacebookGroupMember
Message 1 of 8
FacebookGroupMember
Hello! It is posible to make in fusion 360, aksial following and rotating move of road in same time. I would like to make diferent animation, where is yellow poston fixed (vith comand rigid), and blue (conical cut) cilinder rotate and oscilating in axial direction (follow yellow part). Thanks for ansawers!
Replies (7)
Message 2 of 8
FacebookGroupMember
Maybe contact sets will help. Use a slide joint for the pin and the hole. Not sure it will automatically "pull" the pin back in though.
Message 3 of 8
FacebookGroupMember
This will not work but I have an idea that will work
Message 4 of 8
FacebookGroupMember
On the same principle
Message 5 of 8
FacebookGroupMember
This asembly i wish to run in same time on radial direction - yellow rosette (done), and aksial (conical cut cilinder or some diferent aksial pattern) pattern grey (??? i did not find sistem, how synhronizate both move in same time.
Message 6 of 8
g-andresen
please share meaningful information in screeshots or screencasts and attach a sample file to the next post.
günther
Message 7 of 8
FacebookGroupMember
Dennis Bond Hello! Pleas if you want to share your idea with me?
Message 8 of 8
FacebookGroupMember
Dennis Bond 😄Like this....thank you for"idea"😃
