Haas direct driver: machines not showing up
CS.Paulus
Message 1 of 10
CS.Paulus
I've installed the haas direct driver, but have only been able to connect one of three haas machines in the workshop. I've tried both the search network an direct ip options to connect the machines. Neither will work. All machines are next gen and have the same network settings in the controller. The connecting machine is a CM1, the other machines are a SMM and a VF2-YT. All machines are connected to the network and can be viewed and altered from the windows explorer.
Replies (9)
Message 2 of 10
jon_crandallprecision
im not able to see any machines, i can see them by searching the ip in windows just not fusion.
Message 3 of 10
jason.skipper
I am also encountering this problem.  Machine and computer are on the same network.  Searching through my network and searching via I.P. Address both return no results.
Message 4 of 10
apparently the machine has to be a newer version control software
Message 5 of 10
jason.skipper
I am currently on a NGC UMC-750 Software version 100.20.000.1011.  I know this is not the most current version of the software,  I'm assuming I need to update to get this feature to work?
Message 6 of 10
CS.Paulus
The machine showing up has NGC version 100.20.000.1200
One of our machines running a newer version, 100.21.000.1133 is not showing up. This machine is connected wirelessly connected to the same router the older machine has a direct ethernet connection to.
Message 7 of 10
jack.holmes
Hi everyone, sorry for the slow reply to this I've only just been pointed towards this thread missed it before.
The Haas Driver will require control firmware version of at least 100.20.000.1200, but currently only up to 10.21.000.1133, this version or newer won't work. This is because with this version Haas changed some of the naming conventions meaning the Driver was no longer compatible, but we are working on a fix for this which should be available very soon. If your machine has one of these newer firmware versions please let me know and I will make you aware once the updated Driver is available.
If your machine falls within this "expected" firmware version range but you still cannot connect to it/them, also please let me know and we can work out what else might be going wrong.
Jack
Jack Holmes
Machine Data & Process Insights
Technical Consultant
Autodesk, Ltd.
Talbot Way, Small Heath Business Park
Birmingham, B10 0HJ, UK
www.autodesk.com
Message 8 of 10
kirk3HZ8R
Community Visitor
Community Visitor
Hi Jack, I have this same issue with VF3 running 100.22.000.1015. As soon as there is a fix please let me know. Thanks
Message 9 of 10
jack.holmes
Hi everyone,
A new version of the Haas Driver (V1.36.0) is now available which is compatible with control software version REL-100.20.000.1200 or later, including recent releases up to REL-100.22.000.1014. Download it from the App-Store here - https://apps.autodesk.com/FUSION/en/Detail/Index?id=6029738192084909881
Jack
Jack Holmes
Autodesk, Ltd.
www.autodesk.com
Message 10 of 10
acalkins33
Hello, I have a DS-30y lathe running 100.22.000.1023. I can see the machine when I search for it on the Haas Driver but it does not add it.
