Hello!
I'm trying use Join Origins base on Sketch geometry to align components.
Please look:
We have a.f3z with grounded component and Origin Joins constructed on different sketches in it: Sketch in root component, Sketch in subcomponent
And we insert a.f3z into b.f3z and make Join between Origin Joint from a.f3z and Origin Joint in b.f3z.
File has 3 Joints. You can unsuppress them one by one and see what heppens.
We get the strangest result if wee unsuppress first Joint
Component1 of the design "a" moves relative to design "a" origin. But the component is grounded in a.f3z!!!
Does this Joint override Ground constraint? or there is no contradiction here... so please clarify what Ground do.
If you can explain other 2 joins behavior it would be cool.
Thank you for any your explanations.
