Ground cutting off objects in render
royalcask
Message 1 of 19
royalcask
Why is the ground cutting off my objects when I render? In the render screen on the left it shows it right, I have the objects sitting on the plane in design mode, but when I render the ground is up covering my objects?
Replies (18)
Message 2 of 19
sutherland-
Hi @royalcask
Please try to move the ground plane and see if it resolves the issue:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 3 of 19
P-BvanWyk
Good day @royalcask,
You can go to the scene settings, and under environment, you can change the position (Rotation and z-offset).
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
Message 4 of 19
royalcask
So adjusting that does adjust the ground…but do we really have to guess where to put it and hope it eventually gets in the right spot? The main windows preview and then the actual render are completely off. On another file I tried I pulled the ground completely over the object and it still wasn’t high enough to even start to see the ground…
Message 5 of 19
royalcask
So it’s a guessing game, and a “adjust the ground, hope the render is right, cancel the render, adjust the ground, pray the render is right, cancel the render” until you finally find the ground in the right place? That’s rough.
Message 6 of 19
jhackney1972
You do not have to guess, if your design environment model in on the X-Y plane and you set the Ground Plane to 0 in the Render Environment, the rendering will place the model on the ground.  Since it takes time to render the image, I did not do it in the video but simply attached the result in an image using the setting mentioned.  I am using In-Canvas rendering.
(view in My Videos)
John Hackney, Retired
Message 7 of 19
royalcask
Here’s another file that as you can see, I’ve adjusted the ground to where it’s almost covering the objects…and the ground is nowhere in the render. Ground plans and reflection are both ticked. Tested on my MacBook Pro and Mac Studio and it’s the same issue one all computers.
Message 8 of 19
royalcask
Objects are positioned on the axis’ correctly. As you can see there is no ground in the render.
Message 9 of 19
jhackney1972
I now see your confusion.  The video will show you how to compensate for the ground plane position with accuracy.   As I said, I have attached the result of a Local Render to prove it works.Render to Ground Plane1.PNG
(view in My Videos)
Message 10 of 19
rknightXW6MW
(view in My Videos)
Message 11 of 19
rknightXW6MW
Just realized I'm signed into my other account on this computer, so if the two user names are confusing...that's why. Lol.
Message 12 of 19
jhackney1972
Please attach your model so I can attempt the Render.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
Message 13 of 19
rknightXW6MW
Here you go!
Message 14 of 19
jhackney1972
There is something about this model that brings my computer to its knees!  I will have to play with it awhile and see if I can get it to respond better.
Message 15 of 19
rknightXW6MW
That's interesting, but I appreciate the help!
Message 16 of 19
rknightXW6MW
So, I have to raise the ground 75mm to have it in the right spot...how can this be fixed?
(view in My Videos)
Message 17 of 19
P-BvanWyk
@royalcask,
The XY plane in your design workspace is by default used as the ground plane for renderings.
And it looks like you have a ~2.1mm offset.
The "Re-Anchor" @jhackney1972 mentioned worked on my side.
For future assemblies, I would recommend that you design & ground your base component on the XY plane.
This should completely eliminate the need to adjust the ground plane in the rendering workspace.
Kind regards,
Pieter-Ben van Wyk
Message 18 of 19
royalcask
That doesn’t work. It works for the quick render preview, but not when doing an actually full render.
To get the ground to show I had to ease it 75mm, with a ton of guess work and going back and forth. It’s 2mm off the ground as I like to have a slight gap on renders for these. That’s a personal preference. But at 2mm it should still show shadows and the ground.
Try a full tender and see how it turns out. For me I was unable to get it to render with the ground unless I lifted the ground 75mm up above the objects. Which obviously isn’t how it should be.
Message 19 of 19
P-BvanWyk
The reflections show up the same on my side, but no shadows on the render.
Kind regards,
Pieter-Ben van Wyk
