Grey data panel Mac OS Sonoma 14.5
732595
Observer Observer
732595
Observer
Observer
Hi All,
I have just installed fusion on my Mac and the data panel is grey.
 Running the network diagnostics test yields no insight as it states that there is no network connectivity issue.
I am neither using a proxy server nor a firewall.
Any ideas as to what could be the problem?
Best,
Ryan
RajkumarIlanchelian
@732595 Can you please try the following.
1. Logout and close Fusion
2. Go to https://login.autodesk360.com/login
3. Login
4. This should ask you to create your team hub
5. Once that process is complete, can you now login to Fusion?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Observer
Observer
Thank you so much. This worked.
Best,
Ryan
