Getting errors when choosing machine while creating a new setup.
jpattersonVN4AG
jpattersonVN4AG
I seem to be having issues with my machine library when trying to create a new set up in the Manufacture section. We have a Haas VF-2 and for some reason now all of sudden the local machine in our library won't load when selected, I get the following pop up.
"Cannot load machine model.
The model for the selected machine does not exist on the current Team Hub. Creating references between Team Hubs is not supported.
To use the machine model the model data must be moved to the current Team Hub.
This can be done by exporting the machine and then re-importing a copy."
Okay, seems simple enough to fix. Only it doesn't work. I export the machine, then when I try to import it I get this pop up.
"An unknown error occurred meaning this machine cannot be saved."
So I thought I would just delete the machine and download a fresh one from the Fusion 360 library, I get the same pop up message that started this whole mess. There are only 2 people that use Fusion, we are in the same team, we have 1 project group, and both our names are in the list of members. Everything had been working fine up to Friday, then Monday morning I boot up my MacBook and the first set up I went to do the problem started. I've spent 2 days on Google, reading these forums, I tried to repair my installation of Fusion, I uninstalled and reinstalled. Nothing. Thing is, the other employee that uses Fusion, it works fine for him. So why is my account having the only one with the issue? I'm kind of at my wits end at this point and any help would be appreciated. MacOS is up to date, Fusion is up to date, and this is the same computer I've been using for the last few months without any issues.
sbsadmins23K4R
Observer
Observer
We have the same issue. Since a few weeks ago I cannot load the machines in the setup . Autodesk please help 🙂
mattXK98B
Same issue here. Not sure how to get machine simulation to work anymore...
martinHTJH9
Observer
Observer
same problem - why does Autodesk not respond to these questions?
dhanush9LY6JA
Was the problem solved, I seem to have the same issue and dont know how to solve it
SperlingStudio
Observer
Observer
Same problem here. I cant figure it out.
