Getting Errno 13 Message When Installing
cullenye2005
Message 1 of 13
cullenye2005
I keep getting the Errno 13 message even after I've followed the steps to reset my computer, check directory permissions, and turn off my antivirus. Can someone help me?
Replies (12)
Message 2 of 13
jhackney1972
Have you taken a look at this webpage?
John Hackney, Retired
Message 3 of 13
cullenye2005
Yes. I've already tried what's written on the website and it still doesn't work
Message 4 of 13
jhackney1972
I would suggest you attach your autodesk.webdeploy.streamer.log file.  In it you will identify the folder where the permissions are lacking.  If you need help securing this log file, take a look at this webpage.
Message 5 of 13
cullenye2005
Thank you for the reply! I've attached my log file
Message 6 of 13
jhackney1972
Looked at your log file and this is the first permission error location.  I am guessing that your computer operating system in MacOS as this folder does not exist on a Windows operating system.  I do not know much about how to change permissions on a MacOS so I will not be much help.  One thing I would try first is to give the user "icydemon" full adminstrator rights.  Good luck.
Message 7 of 13
cullenye2005
I'm kind of confused though as when I follow the folder path, it seems that Autodesk Fusion 360.app does not exist.
Message 8 of 13
jhackney1972
That is correct, the folder lacks the permissions needed for the file to be written to it.  Later on in the log file it mentions it could not find the file Autodesk Fusion 360.app to use and then remove it.
Message 9 of 13
cullenye2005
So currently, I just set the permissions for the Application's folder such that anything can read or write in it and it still seems to not be working. Is there a way to have the file appear?
Message 10 of 13
jhackney1972
Now that you say anything can be written to the folder, what have your done to say "it is not working"?  Have your run the installation program again?  If the installation application runs correctly, the file is written, used and removed during the process.  I was just guess you are on a Mac, if I were executing the installer, I would right click on the program and choose "Run as Administrator" but I do not know the equivalent on the Mac.
Message 11 of 13
cullenye2005
HOLY JESUS I FIXED IT. Thank you so much! It turns out that I had to set the permissions for a general administrator account instead of just my current profile.
Message 12 of 13
jhackney1972
Congratulations!  For my own learning, ARE YOU ON A MAC?  You have never told me for sure.
Message 13 of 13
cullenye2005
Oh sorry about not addressing that question. Yes, I am on a MAC
