Get Latest is crashing Fusion
Jonathan0137
Jonathan0137
In one distributed design I have I can't get the latest versions of the individual components. No matter if I select to get all the latest versions or just for one component, Fusion crashes. The file contains quite a few toolpaths for different components, which might cause this issue but I never had a problem with this before.
In other files, this is not an issue, even with many more components.
jhackney1972
I tried to recover the assembly also.  Opened each file, updated and saved as necessary.  Opened the assembly, tried to update components but crashed repeatedly  This is one for the support team Jeff Strater. @jeff_strater .
John Hackney, Retired
RajkumarIlanchelian
Thank you for posting the design. We will have the appropriate team look at this.
(Jeff is on a well deserved vacation 🙂 )
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
prakash.kumar32QRY
Thanks, John
For reporting this bug.
I am able to reproduce this issue. I am coordinating with my team to get this fixed soon
Meanwhile, i am looking for any workaround to get rid of this crash.
I will get back to you if i get any update.
Prakash
Prakash Kumar
SQA Engineer
Quality Assurance
jeff.pek
Hi John - Initial investigation shows this to be an update issue related to the use of the manufacturing working models preview. We believe that if you re-target the setup(s) to the primary model (i.e., "default"), and then delete the working models, this can be made to work again. You would need to reestablish any model references after doing this.
Sorry for the inconvenience, and thanks for letting us know about this. We are considering oushing a fix for this in a near-term update.
Jeff (not Strater)
Jonathan0137
Thank you. I turned off the working model preview future and now it works again.
