[Generative design] Modify model
Hello everyone,
I am using Fusion 360 Generative Design. I modified (quite a lot) a model based on step files, which I imported into the Design module. However, I just figured out that I should have modified my model in the Generative Design module instead of the Design module. Now as soon as I want to edit anything in my model, all my Generative Design Studies become "out of date". In the present case, I would need to have one Fusion file per Generative Model. I hope I am clear enough...
So, is there a way to transfer all my modifications to the Generative Design module "Modify model" tab ?
By the way, does editing the model in the Generative Design module allows as many functionalities as in the Design module ? For instance, I don't find the T-splines tools, which I needed to use while editing...
I just have a last question : when applying forces, the checkbox "Per entity" is checked and greyed out. How can I uncheck it ?
Thanks a lot and best regards
Raphael
