Fusion360 won't start on latest Windows 10 Insider build (19030)
Message 1 of 224
OS Name: Microsoft Windows 10 Pro
OS Version: 10.0.19030 N/A Build 19030
Attempt to start program, it will freeze and never get to the splash screen. I'm available to grab whatever info you need from the process, since it doesn't die. It's just hanging.
Replies (223)
Message 21 of 224
Unfortunately rolling back is only an option for upgrades performed in the
last week. If you upgraded say 2 weeks ago and didn't catch this bug then
you are SoL.
Message 22 of 224
familien_enholm
yeah, looks like the newer insider builds might have some new updated security, probably on the network side.
So this might be something that the Autodesk team will need to fix, normally the insider builds shows us how things will be when it gets released 😉
Is it possible to tag someone from Autodesk here, or do they read everything ?
I am new here, so don't know how this forum works 🙂
Message 23 of 224
I often feel SOL with the insider builds, but it's almost impossible to turn them back.
Message 24 of 224
The last time this happened about a year, maybe almost 2 years ago, Autodesk had a solution inside a week.  It doesn't help that this happened over the holiday weekend though.
Message 25 of 224
familien_enholm
Been an Insider since 2014, and usually you can work around stuff like this, but haven't been able to figure out what actually is wrong this time.
20H1 branch are more or less ready for release now, so this should be looked into...
Message 26 of 224
Mine has more comments so let's merge those other into this one 😛
Message 27 of 224
The whole point of windows insider is to test the latest version so if you want a stable version should just not hop on the insider ring. Problem fixed for you 🙂
Message 28 of 224
Steverc101
Observer
Observer
Same here Fusion 360 will not start but shows running in background processess !!!!!!!
Message 29 of 224
...and so you can work with vendors to get ahead of issues before they hit
the general community.
Which is what we're doing by reporting and sharing logs and actions we've
tried to get things to work.
No one here is complaining. We're all on insiders build and we all know the
risks.
Everyone is just saying "me too" so the devs are aware it's not an isolated
incident that might be chalked up to PEBKAC problems.
Message 30 of 224
For me it is not working on Build 19028,19030,19033. I checked the logs (the same as already stated in this thread) und I had a look with Procmon and Process Explorer but I did not find any differences to the startup in build 19025. I returned to 19025 for now but follow this thread if there are any changes. There are also messages open in the feedback hub of microsoft, so I think this problem will be solved after the holidays...
Message 31 of 224
Just here to add my +1 - build Windows 10 19033.1
Message 32 of 224
I already posted on another thread.  But posting here as this thread is getting more traction???
My OS Build is now 19033.1 but have the exact same symptoms. I did a complete Windows 10 Reset, to no avail.
Steve
Message 33 of 224
Same issue here.
Message 34 of 224
jsroques_web
Hello all,
Same issue for me on insider build 19033.1
I already posted here but seems this topic is getting more traction than mine so +1 for me !
Jean-Sébastien
Message 35 of 224
Same issue here:
Windows 10 19033.1
When I start F360, none of the F360 logs update or anything.  F360 sits in background tasks using 13.8MB and no CPU GPU, Network, or Disk.
Message 36 of 224
npaLSBDV
Having the same issue with 19033.
Message 37 of 224
andyNY4FG
Just to add my name to the list, running 19033.1 and Fusion360 doesn't start for me either. It shows in the Task Manager, but doesn't show anything on the screen. The log doesn't show any errors, just info and debug messages.
Message 38 of 224
scruff.r
Would be nice if there was a simple "I got the same problem" button for the original post.
Seeing how many people just had to create a separate post merely to state they see the same thing, seems cumbersome.
However, I do see the same thing 🙄
Message 39 of 224
gerard_reidy
One more here... 19033.1
Message 40 of 224
info46GP8
Observer
Observer
I have the same issue too!
