Cannot switch laptop graphics to high-performance for Fusion 360
I have finally installed Fusion 360 on my laptop, but I am having difficulty solving a problem in order to use the program, and though I've tried many solutions, I keep running into dead ends.
When I open the program, the display seems to be really off. It's nothing but a gray background, and if I open a file I've worked on, it is invisible in the grayness. I also get the following message:
"Your graphics card might not be optimal to run Fusion 360. Open Graphics diagnostic from the help menu for more information."
I follow the instructions, and find that the Graphics Diagnostic tells me the program launched with the integrated graphics instead of the high-performance graphics. I go to the Autodesk page online, and find that there is a page which describes this problem, and how to fix it:
I begin following the instructions, including changing the performance options to "High Performance," though in the picture they include they show options that aren't available to me on my machine. I then attempt to follow what comes next: configuring custom settings for Fusion 360 on the NVIDIA driver software. It gives 4 steps that I try to follow.
#1) I try to follow Step #1 the best I can, and though NVIDIA's website has an error that says it needs Java to operate (even though I previously downloaded the latest version already; I beleive it's a problem with Java, web browsers, plugins, etc.), I download their GeForce program instead and find that my graphics driver is up-to-date.
#2-3) I follow these steps exactly as described
#4) This is where one of my dead-ends is. No matter what I do, if I right-click, it never brings up "Run with graphics processor" as described--it is never mentioned, no matter what boxes I check or uncheck in the NVIDIA menu.
So, I don't find any other helpful information on the page and try to find a different way around the problem. Navigating Autodesk's support website, I find another page which seems to describe the problem I have and how to fix it:
I begin following the numbered steps on that page for an NVIDIA graphics card:
#1) Again, as far as NVIDIA's GeForce Program says, my graphics driver is up-to-date.
#2) I run into the same problem again, when I right-click, that option isn't available to me, no matter what I do. It then says "Alternatively...", and I then follow the #1 and #2 steps that follow. (i.e. navigating to the appropriate place in the NVIDIA Control Panel).
#3) I try to "Select a program to customize...", but Fusion 360--or anything related to Autodesk--is not listed. I deselect the option that says "Show only programs found on this computer", and still nothing shows up in that list. I try clicking the "Add" button, but the program is nearly impossible to find. I try three separate times to find an .exe file that I will be able to select, and I choose the shortcut on the desktop, the Program Launcher in the installation folder, and the actual Fusion 360 .exe file in that folder, respectively.
#4 and #5) I then follow these steps for each .exe file, and test to see if any of them worked in Fusion 360. None of them worked--the Fusion 360 Graphics Diagnostic still lists the program as using the integrated graphics and not the high-performance graphics, and I can't find any other .exe files which might work.
I even tried switching my entire machine to using the high-performance graphics and not just Fusion 360, and my computer began becoming unresponsive, leading to a restart and a system restore--and finding myself back at square one.
I've tried to describe the best I can what my problem is and what I've tried to do to fix the problem on my own. I've tried to read anything I can on Autodesk's support website, reading questions and responses on forums, searching for information anywhere--and nothing seems to help. If anyone out there could help me figure out what seems to be wrong, I would appreciate it!
