Fusion360 will not open
guillermo.baselga
Message 1 of 51
guillermo.baselga
I  come to this forum as my last resource, since ive tried everything i could and I just can not get the fusion360 program to work. When the program opens, it launches as normal, but when trying to open the log in, it recognizes the click, but just does not open the browser. Here is a list of all the things I've tried so far:
- Install and reinstall
- Repair the program and Reset the program from Fusion Service Utility
- Reinstalled the AdSSO (and then rebooted)
- Checked the path on "HKEY_CURRENT_USER\Software\Classes\adsk.idmgr\shell\open\command"
- Deleted the "%localappdata%\Autodesk\Identity Services\WebView2" folder
After every single step, I have restarted both the program and the computer, to no avail. I am trully lost, and would gladly take any help i can get.
Ive linked the before and after click on the Fusion 360 app (its in spanish but its just the default messages)
Replies (50)
Message 21 of 51
CGBenner
@RajkumarIlanchelian
Hello, sir.  Is there anyone who can take a look a this?  Do you need anything from @chrisvicseks ?
Chris Benner
Message 22 of 51
RajkumarIlanchelian
@chrisvicseks Couple of things to try. I assume when you click on sign in , nothing happens.
1. Can you change your default browser and see if that helps?
2. Do you have other Autodesk products installed on this machine?
3. If you go into add/remove programs - do you see Autodesk Identity manager installed?
4. Are you able to successfully login to https://login.autodesk360.com/login
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 23 of 51
chrisvicseks
Hello @RajkumarIlanchelian
Thanks for replying
1. I have changed my default browser, but still nothing worked. I followed to steps on this link on how to resolved the issue but nothing worked (https://help.autodesk.com/view/fusion360/ENU/?caas=caas/sfdcarticles/sfdcarticles/Sign-in-in-Fusion-...)
2 I have an autodesk product installed (autodesk powershape)
3. I also have the autodesk manger installed too
4. I am able to login to the my account.
Message 24 of 51
RajkumarIlanchelian
Message 25 of 51
chrisvicseks
It still didn't sign in
Message 26 of 51
RajkumarIlanchelian
@chrisvicseks Can you pleas provide the below information?
  1. Close Fusion
  2. Go to add/remove programs
  3. Select Autodesk Fusion - Modify
This will launch the Fusion service utility
  1. Run the "Gather system info"
  2. This will generate two zip files
6. We will need the Fusiondoagnosticslogs.zip
Autodesk Fusion
Join Fusion Insider
Message 27 of 51
chrisvicseks
I didn't see any pop ups that has the file
But on this chat I have seen you suggested a manual fix for that
I followed the link and I have these
Message 28 of 51
chrisvicseks
And also
Message 29 of 51
RajkumarIlanchelian
@chrisvicseks Thank you for the logs. I am consulting with our engineering team with regards to the logs. Will post back here.
Autodesk Fusion
Join Fusion Insider
Message 30 of 51
RajkumarIlanchelian
@chrisvicseks Can you please delete the below registry key and then launch Fusion? (Delete the AdsjIdentityManager.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AdskIdentityManager.exe\Debugger
Autodesk Fusion
Join Fusion Insider
Message 31 of 51
chrisvicseks
This worked
Thank you so much!
Message 32 of 51
RajkumarIlanchelian
@chrisvicseks @Glad to know that this worked.
Autodesk Fusion
Join Fusion Insider
Message 33 of 51
mehdi.boulsane
Hi, I hope everyone is doing well.
I have the same problem. I followed all the instructions and steps that worked for some but without success.
I cant luche the browser to sign in.
I do not what to do.
Message 34 of 51
RajkumarIlanchelian
@mehdi.boulsane Can you please follow this link and get the logs for us?
https://forums.autodesk.com/t5/fusion-support/fusion360-will-not-open/m-p/12961039#M202072
Autodesk Fusion
Join Fusion Insider
Message 35 of 51
mehdi.boulsane
thank you for replying Rajkumar Ilanchelian.
I think the link is for this for this discussion.'https://forums.autodesk.com/t5/fusion-support/fusion360-will-not-open/m-p/12961039#M202072'
Message 36 of 51
RajkumarIlanchelian
@mehdi.boulsane Look at message 26 of this thread.
Autodesk Fusion
Join Fusion Insider
Message 37 of 51
mehdi.boulsane
thank you here is the zip file
Message 38 of 51
mehdi.boulsane
finally, thank you for the solution in message 30
Message 39 of 51
RajkumarIlanchelian
@mehdi.boulsane Glad the solution worked.
Autodesk Fusion
Join Fusion Insider
Message 40 of 51
maxleajimkd
ich habe ein ähnliches Problem denn wenn ich es öffne und auf anmelden drücke kommt
Um sich bei Fusion anzumelden, benötigen Sie die Microsoft WebView2-Komponente, die auf Ihrem Computer fehlt. Sie können sie direkt von Microsoft herunterladen, indem Sie das für Ihr Gerät geeignete Evergreen Standalone-Installationsprogramm verwenden.
Weitere Informationen
ich habe alles befolgt aber es kommt das es bereits installiert ist was kann ich tun
