Fusion360 not responding when opening a model
hwiguna
hwiguna
More and more, I'm seeing Fusion360 not responding when I open a model.  The Browser panel is black, and it never finish opening.  I have to end the program and re-launch.  It usually works the second or third try.
I'm using a Lenovo Yoga C940 with 16GB RAM and 1TB SSD.
What can I do to improve my user experience? Thanks!
RajkumarIlanchelian
Sorry that you are having this experience. Can you help answer a few questions?
1. Is this one particular model or is this "any" model"
2. If you go to your help - support and diagnostics - Diagnostics log files - This will generate a file. Can you please attach the file here?
it will help us analyze the logs to see what could be going on.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
hwiguna
1. It does not do it to any model. I think it has to do with complexity of
the model. But the same model eventually opens if I try several times.
2. I will try that the next time it happens.
Thank you.
