Fusion360 cause high heating/loud cooler/fast battery draining.
Hi there.
In my case, I m working on a brand new Macbook Pro 13'' 2019, and ..as u can read the title..it's causing big problems from the first minute of opening the Fusion360.
The F360 app, is using around 160% of my CPU...said the monitor application.
I must say, when i'm using F360, 0 applications are in use except the F360.
The battery is draining really bad, like 2% in 1 minute.
I don't have installated any 3dconnextion mouse or something.
Any ideas of solutions please?
Thank you, mates ! 🙂
MoshiurRashid
Please visit this post and see the accepted solution. I'm pretty much sure that you are facing the same situation.
https://forums.autodesk.com/t5/fusion-360-design-validate/fusion-360-using-over-100-of-cpu-at-idle/m...
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Thank you for the reply.
It didn't actually helped me, but i found the solution.
When my macbook is offline, the cpu is going crazy to 160%, but when i have a connection the cpu is running at 8-10%.
So i switched the F360 to offline work, and now it is fine.
Hope it will help somebody with the same problem :). All the best !!
