Fusion won't load any of my projects.
justinmdougherty
Message 1 of 9
justinmdougherty
Starting yesterday I went to draw something and I opened up Fusion and it wouldn't load any of my previous projects. I didn't catch the blue banner the first time so I restarted and same thing, and saw the banner from attached picture. I drew up what I needed to print and then it wouldn't let me save it, which wasn't a big deal so I figured I would give it until today. My computer was restarted so it was a fresh boot and I opened the program and same thing. I logged out and back in and same issue. I also when to the health website and it shows all services are good.  Anyone have any insight?
Justin
Replies (8)
Message 2 of 9
jhackney1972
Have you tried to log into your Fusion 360 web database and verify your account and projects?
John Hackney, Retired
Message 3 of 9
justinmdougherty
It's all there, won't populate while in the program.
Message 4 of 9
jhackney1972
Have you closed Fusion 360 and restarted you system?   I cannot read the top banner in your original post screen capture.  What does it say?
Message 5 of 9
jhackney1972
I got my magnifying glass out and read the message.  Did you find this Autodesk article on the issue?
Message 6 of 9
justinmdougherty
I mentioned in my OP that I closed the program and reopened, restarted the computer, and logged out and back in.
It says "Requested web service is unavailable."
Message 7 of 9
azimshaikh95
Hi @justinmdougherty
Please try these methods. Probably you will get it resolved
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
In short
Mac OS
Note: While working through the following instructions, you will need to be able to access hidden files and folders on   Mac.
  1. In the Subsequent Finder window (Macintosh HD > Users > %Profile% > Library), browse to ~/Library/Application Support/Autodesk/Web Services
  2. In the Web Services Directory, locate the file LoginState.xml
  3. Right click on LoginState.xml and select Move to Trash
  4. Restart Fusion 360
Windows OS
Note: While working through the instructions in this article, you will need to access hidden files and folders on   Windows.
1. (Close Fusion 360) In windows explorer browse to  C:\Users\<username>\AppData\Local\Autodesk\Web Services
2. In the Web Services directory, right click on the Login State.xml file and select delete
3. Restart Fusion 360
Thanks & Regards,
MohammedAzim Shaikh
 Please use the Accept Solution button to mark any posts that provide the answer or solution.
 Likes are always welcome.
 LinkedIn | Instagram | Facebook | YouTube
Message 8 of 9
justinmdougherty
Thanks for the suggestion, I cleared cache data and deleted the file and no difference. Continues to not load my projects (though it appears to flash them in the list before they disappear) and continues to display a blue bar at the top of the list that says "Requested web service is currently unavailable" When Fusion first loads it showed the "recovered Documents" dialog which I could use to open some of my old projects so they're still connected somehow.
Message 9 of 9
justinmdougherty
It appears that even though the program wasn't loaded and I did not activally connect, my VPN was running. I'm not sure if being connected to a VPN typically prevents Fusion from loading properly but in this case it did.
