Fusion won't leave offline mode?
HughesTooling
Consultant Consultant
Message 1 of 69
HughesTooling
Can't go online, data panel shows offline and no option to go online in the menu!
ark
Mark Hughes
Owner, Hughes Tooling
Replies (68)
Message 21 of 69
ARTHUR-HM
Everything back to normal for us now.
Message 22 of 69
HughesTooling
@Anonymous my computer that worked OK today updated and still logged in after the update so it's not that. The computer that wouldn't go online today was fine yesterday after updating.
Mark
Mark Hughes
Message 23 of 69
brianrepp
@Anonymous - I responded to your email with (hopefully) a solution.  We don't believe the issue is tied to the update, but rather a series of small service issues that triggered taking Fusion into offline mode, but failed to authenticate properly to allow a return to online.
If others are still stuck offline, please let me know.
Message 24 of 69
thanks, it fixed the issue for me.
Maybe you should post it here just in cas others have the same problem.
In my case fusion 360 was prevented from connecting once by my firewall and I restarted it but it happens eveytime it updates and never was an issue.
Message 25 of 69
brianrepp
Good to hear @Anonymous.
<<EDIT>> Nate Chandler's next post has a solution that should work if anyone else runs into the issue.
Message 26 of 69
innovatenate
Autodesk Support
Autodesk Support
If anyone else experiences this issue, can you try the following?
Remove the LoginState.xml file and Restart Fusion 360:
Mac OS
1. (Close Fusion 360) In Terminal, type the below command and press enter
open ~/library/
2. In the Subsequent Finder window (Macintosh HD > Users > %Profile% > Library), browse to
~/Library/Application Support/Autodesk/Web Services
3. In the Web Services Directory, locate the file LoginState.xml
4. Right click on LoginState.xml and select Move to Trash
5. Restart Fusion 360
Windows
1. (Close Fusion 360) In windows explorer browse to   %localappdata%\autodesk\web services
2. In the Web Services directory, right lick on the LoginState.xml file and select delete
3. Restart Fusion 360
We have had some success with this procedure already so I think it may also help.
Nathan Chandler
Principal Specialist
Message 27 of 69
MathieuHebbrecht
Hi innovatenate,
I'm unable to follow your instructions. Terminal gives me a message that the folder does not exist.
What can I do to get back online. I really have to continue my work, I have a deadline tomorrow!
My system, mac book pro with Sierra. latest fusion update. No clue why i'm in offline mode.
EDIT: found the library folder, but cannot continue the folder path... In the folder autodesk there is no folder named 'web services'. Only 'Adlm' and 'ADUT'.
Message 28 of 69
brianrepp
@MathieuHebbrecht - it's sounding like you might not be in the right folder.  When you open terminal, did you enter exactly "open ~/library/", with the space after "open"?
Message 29 of 69
innovatenate
Autodesk Support
Autodesk Support
You should make sure that you're in your User Library and not the System Library folder.
In the View Menu for the Finder Window, make sure that you have Show Path Bar enabled.
The full path will look like this:
If the open library command is not working in Terminal.
You can select the Go drop down menu in Finder. Hold down the ALT (Option) Key on your keyboard.
When you do this, the Library directory will appear.
If you select Library it should get you to Macintosh HD > Users > %username% > Library..
Please give that a try and let me know if it helps!
Nathan Chandler
Message 30 of 69
Beyondforce
Thanks @innovatenate, the fix is working!
Ben Korez
Fusion 360 NewbiesPlus
Gript.app
| YouTube
Message 31 of 69
kwongkan
I have the same problem, did I look at the wrong directory or something else went wrong? It's empty inside.
Message 32 of 69
brianrepp
@kwongkan - is it possible that you are actually running the version from the Mac App Store?  If so, would you mind trying the direction suggested in my original post of this thread?
Message 33 of 69
kwongkan
@brianrepp Yes, it's from the App Store, and BOOM! It worked! Thank you very much!
Message 34 of 69
brianrepp
Great to hear - sorry for the trouble!
Message 35 of 69
MathieuHebbrecht
Hi innovatenate,
Thanks for the help! The library folder was hidden. Also I'm from Belgium, and my Mac OS version in in dutch. So my library folder was translated to dutch as well (library mean bibliotheek in dutch). Very weird that I couldn't refer to the library folder in the terminal window. I would expect that it is default english, since all command are...
However, problem solved. I was able to finish my work. Thanks a lot!
Message 36 of 69
innovatenate
Autodesk Support
Autodesk Support
Glad to hear it! Thank you for following up with us here to let us know what worked.
Nathan Chandler
Message 37 of 69
mike.chambers
Thanks, that fixed it!
For our Window 10 users:
c:\users\username\AppData\Local\Autodesk\Web Services
where "username" is not literal but the actual login username
Message 38 of 69
LMD001
@innovatenate
Hello Nathan,
Had the same offline issue yesterday, quit and restarted Fusion 360 this morning and all seems OK.
No computer restart and strangely enough, for now, I did not have to do the proposed LoginState.xml fix.
Just thought I'd mention it.
Best regards,
Ludo
Message 39 of 69
LMD001
This afternoon Fusion 360 went offline again, had to apply the LoginState.xml fix.
All good now.
Best,
Ludo
Message 40 of 69
bmxjeff
Nathan,
Got to work this morning and it was stuck in offline mode. Deleted the xml file and I'm up and running. Thanks!
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
