Fusion will not open, will not reinstall
Aj7306
Observer Observer
Aj7306
Observer
Observer
Fusion will not open. I click the icon, and nothing happens. I tried reinstalling, and got the Errno 22 error. I renamed the webdeploy folder, and didn't have the other folder that the help article suggested. I rebooted and tried to reinstall, and got the same error message. My log file is attached. Thanks for the help.
RajkumarIlanchelian
@Aj7306 Please try below steps to install Fusion.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Aj7306
Observer
Observer
It still won't install. When I clicked on the button to open log file
location, the folder it took me to only has the log file from 3/25/25. I've
attached it just in case.
[image: image.png]
RajkumarIlanchelian
@Aj7306 @Is it showing the same error 22?
Autodesk Fusion
Join Fusion Insider
Aj7306
Observer
Observer
Yes, this is the error, I guess it didn't come through in my last post:
Aj7306
Observer
Observer
It also won't allow me to uninstall.
RajkumarIlanchelian
