Fusion will not install
rfazio1951
rfazio1951
Community Visitor
Community Visitor
I had Fusion on my machine for some time. I just upgraded with a new machine. I wanted to reinstall fusion. I'm using the personal use version. I have designed simple items and printed them on a 3D printer. I wanted to do so again. I cannot get the latest version to install correctly on my Windows 11 machiine. A brand new machine I just got up and running. Fusion says it's installed but there is no program or app installed. I have a blank icon on my desktop that does nothing. When I try to reinstall it, it says it's already installed, do you want to run it? I say yes and I get this message.
Configuration file C:\Users\Richard
Fazio\AppData\Local\Autodesk\webdeploy\production\6a0c9
611291d45bb922698029917c3d\FusionLauncher.exe.ini' is
missing or incomplete.
Please re-install the application, and contact support if this
does not resolve the problem.
dsouzasujay
Hi @rfazio1951 ,
Could you please follow below article and see if the solution helps?
"Configuration file 'Fusion Launcher.exe.ini' is missing or incomplete." when launching Fusion
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
