Fusion update always results in Application Not Respomding (Mac Catalina)
chrisQX8DX
chrisQX8DX
this has happened for the last dozen or so updates. When i click update in Fusion the counter completes, the there is a second Fusion icon popping up in the Dock and the Fusion splash screen from that app is overlayed over the previous Fusion window, then the first application icon disapears from the doc and the Fusion splash screen remains .. and the application is not repsonding with the beachball of death cursor. If i force quit and relaunch Fusion it starts up correctly. So not a show stopper but definitely something wrong with the update procedure.
Mac Catalina 10.15.7
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
chrisQX8DX
a couple of updates later ... still the same problem
