Fusion Teams - Public Share Link Regenerating
william
william
Hello Fusion Support
This relates to an earlier post, see https://forums.autodesk.com/t5/fusion-360-design-validate/fusion-teams-public-share-link-regeneratin...
I have discovered a particular workflow that causes a different share link to be generated, and I suspect it is not intended to work this way. Please watch the attached screencast to see the workflow.
Step 1: Create version and generate share link
Step 2: Open share link in seperate tab.
Step 3: Upload new version, in my instance this is done with iLogic rule saving the pdf to the desktop connector folder to overwrite the existing PDF, triggering a 'synchronisation'
Step 4: Click the share link button on the open tab, it will display a different share link url to the original.
Step 5. Refresh the tab and check the share link url again. It matches the original.
Even if you 'go to' an earlier version and click the share link button, it will display the original share link.
Am I correct in asuming this is a bug in the software?
william
@Rafal.Chlod
Any thoughts on this?
william
Hello..
Is there anyone at Autodesk who can answer this?
